Old 14 Nov 2004, 11:21 am
ElectricBlueGT ElectricBlueGT is offline
Gary,
When the light came on the first time, you checked the oil, right? Was it considered "full?" If so, it is more than likely a bad oil pressure sending unit. It can be an intermittent problem. Since you had an oil light, you have a stored code. Your dealer can check it out and have it replaced under warranty.
BTW, this happened to me and the replaced sending unit has been perfect since.
Scott
\"If you choose not to decide, you still have made a choice.\"
