Old 16 Nov 2004, 03:31 pm
unfortunately it would be a real pain to make that work without a stand alone enging management system like a haltech. Many, many changes to the wiring harness and computer were made for the 2003 model year. one example is the crank position sensor location and output signal. you would need the PCM from the '03 to make it all work especially with the automatic transmission.
my opinion, its not worth the effort.
The hahn turbo at only 5psi will do no harm to the engine and will definitely make a huge difference. That will run you around $2500 from Bob Stockum (buy from him for best savings) which is still at least a grand cheaper than a S/C plus it is the base point for a system that could put your car up to 300hp.
