From what I understand the engines are still the same it's the intake, turbo, intercooler, manifold, PCM and all the ducting involved. Wow when you look at it that way I guess it is a whole new engine. I know that the placement of things in the egine bay are different to make room for the extra components so you might need to also check if everything will mount up correctly. Sorry I wasn't more of a help, but I'm sure someone on this forum will have some advise for you.
03 Black PT GT: BTG Strut Tower Brace, BTG Rear Anti Sway Bar, Psi-Fi Control Arm Bushings, H&R Wheel Spacers, Mopar Stage 2 Coilovers, Yokohama AVS ES100, Stage 1, Uppper Charge Pipe, Mopar Plastc Manifold.
Mods On The Way: AGP Wastegate Actuator
