Old 20 Nov 2004, 01:13 am
PT2NV PT2NV is offline
quote:Originally posted by Dragula
The manual brake and clutch pedal reportedly only require a new pad.
Actually, the manual transmission brake/clutch pedals are different shape and size on '04 vs '03 . . . not a simple replacement.
The '04 and newer (metal/rubber) pads are shorter and wider. '04 pads can be made to fit by grinding about 1/2 inch off the bottoms of the '03 brake/clutch pedals. That makes a good fit in height. As for width, I used a little RTV on the back of the pad when installing, and mine seems to be holding on well, speaking after a year in use.
Gas pedal requires entire assembly, as stated prior.
Dream Cruiser II #624
Staged . . Sprung . . Swayed . . Shifted . . Shaved . . . Shiny
