Thread: Hyperground
Old 21 Nov 2004, 04:10 pm
littleblueGT littleblueGT is offline
Did you solder the wires to the eyelet ends? I soldered mine as I figured it wouldn't hurt and should make better contact as well as keeping moisture and corrosion out.Just the wires from the battery to the head, and from battery to PCM seemed to make a difference.That change coupled with the NGK Iridium spark plugs makes the little GT pull harder to redline.I saw the gold plated eyelets at kraigen auto, but they were too large and there wasn't a very good selection size wise.
