quote:Originally posted by dwysywd
If you have access to a lift - BY ALL MEANS USE IT! There is a service hole you can access bolt 3 from below. BUT DON'T try it by putting the car on jack stands. The only way to get to it is by standing under the car, you will never get your arm in the correct position if you are lying on your back.
Good luck.
Unless you have a stick, then the shifter cable gets in the way.
