Thread: BOV Upgrade Kit
Old 22 Nov 2004, 07:55 pm
Cal Cruzer Cal Cruzer is offline
quote:Originally posted by rice_killing_GT
quote:Originally posted by dwysywd
If you have access to a lift - BY ALL MEANS USE IT! There is a service hole you can access bolt 3 from below. BUT DON'T try it by putting the car on jack stands. The only way to get to it is by standing under the car, you will never get your arm in the correct position if you are lying on your back.
Good luck.
I beg to differ, I have done 3 BOV installs using Rhino ramps. 2 auto-sticks at the track and 1 5sp at home. I agree with Cal Cruzer 5 speeds have less room because of the shifter cable. But you DON'T need a lift.
No, I meant it was easier for me to do it from above than from below with the 5 speed. I couldn't get my hands up in there.
