quote:Originally posted by quicksilverdon
quote:Originally posted by MichaelDay
If you have a 2003 GT your injectors are not compatible with the 2004+ turbo lite progamming so there would be a problem switching ECU's back and forth.
Damn. It's a 2003.
My thought was to have a less-stressed engine running on regular gas, and have the ability to go all-out if I chose to.[:I]
Even if you sapped out the injectors I don't believe that the PCM would let everything run right. Someone tried a 03 Stage 1 in an 04 before the S1 for 04 came out and the AC and other components did not work.
