Old 30 Nov 2004, 01:55 pm
littleblueGT littleblueGT is offline
[8)]I insulated my up charge pipe and the lower IC pipe using flexable aluminum heater/dryer exhaust tubing 3in dia.There is air between the aluminum pipe and the OEM rubber pipe and acts as an insulator.I found that in stop and go traffic on the freeway in 100 deg temps the throttle response was sluggish, especially with the AC on. After the modification the PT was more responsive. As the IC pipes are behind the radiator hot air is blown over them when driving and when the fan is operating in traffic, this mod seemed to help. Hope it helps some of you. Caution,aluminum is conductive,the pipe is in close proximity to the positive battery terminal.Put insulation around the bat terminal clamp so there is no metal to metal contact.
