Old 30 Nov 2004, 04:00 pm
Rybo Flavin Rybo Flavin is offline
quote:Originally posted by RallyDRock
does it pull to the left the same all the time? usually camber out of spec would cause lateral pull.
I had the alignment done...everything is in spec now, and the ball joints were fine, but it's still pulling to the left when coasting. Once you hit the gas and apply torque to the wheels, it straightens out perfectly...let off the gas and it starts hooking to the left again. I tried rotating the tires one more time, but it has no effect. Also, I changed tire pressure to 40 lbs. on drivers/front & 30 lbs. on passenger/front and it helped a little bit by putting more drag on the right side...but it's not a good permanent solution, that I do know.
Any other ideas?
