Old 03 Dec 2004, 04:09 pm
Cal Cruzer Cal Cruzer is offline
quote:Originally posted by Kirby
Turning the rotors is sooo cheap,(free at some auto parts stores), why not do it should be the question.
Kirby does make a good point. You can get them turned at some parts stores for about $5.00 per. But if there are no grooves or wobble or anything I probably wouldn't do it just because it will take some wear potential off the rotor. If you have a good machinist that will do a runout first and see if or how much it would take, then do just the bare minimum, perhaps. I am not sure if Kragen will be that carefull.
