quote:Originally posted by 2step
Yes...pad wear and low fluid level will do that. In my own case, I continued to drive a few more weeks and the warning light stayed on for a progressively longer time. After brake job, all is well.
That's what it was with mine. If you add fluid, when you push the pistons back when you do change pads, the master cylinder may overflow.
I changed pads instead & found the originals had about 1/2 thickness left. I don't regret it - put in Raybestos ceramic pads and NO DUST.
