Old 07 Dec 2004, 11:38 am
chaase chaase is offline
quote:Originally posted by RallyDRock
the aux input converter, where does this device plug into the stock head unit?
When I had my amp connected to factory HU I used a converter to change speaker level inputs to preamp rcas, does your converter work in opposite fashion? Mine had level control on the converter but i have seen others that did not.
The Aux Input converter plugs into the gray connector on the back of the head-unit. It plugs in where the factory changer would plug in. The Aux Input converter doesn't have any adjustments.
You plug it into the head unit and you get RCA in.
Chris
