Old 07 Dec 2004, 05:20 pm
purple04 purple04 is offline
P1604 is "PCM internal dual-port RAM read/write integrity failure". The test checks for power to the PCM with key on. If the power supply is okay, you replace the PCM, period. [:O] Sounds like you have an intermittent power problem or the PCM is dying internally. You could check connections, but this should be covered under warranty.
