Hey, if you haven't left yet, here are a couple suggestions;
1. check injector pulse width coasting downhill in gear (throttle off) and then with the clutch in or in neutral. Might see one a bit lower than the other for all the guys who want more mileage.
2. Engine load difference with A/C on/off at steady cruise.
3. Engine load difference with window(s) up/down.
4. boost curves in each gear
5. maybe try regular fuel and drive easy, while checking knock sensor status
6. This one may shock, but with cruise on, try a freeway section with curves and check load. You may see how good the alignment is...
