Old 21 Dec 2004, 11:08 am
Dalite Dalite is offline
quote:Originally posted by EDGAR TAMAYO
Hello!!
Just a question is normal that stage1 give you a 15 psi in the GT ATX? I mean 15 psi in each gear..... You have the same psi in your cars?
Thank you!!!
When outside temperatures are higher, boost is higher.
When outside temperatures are lower, boost is lower.
There is some inherit accuracy problems in nearly every boost gauge, making their only relative measurements.
