Did'ya lean the seats all the way back?? Also you can remove the arm-rest itself. That helps a little bit, but the plastic pivot still makes it tight. [:I] Also try to lift the back of the console straight up while at the same time trying to pivot around the front edge. {Geez, even I don't even understand what I just said!!}
Good Luck
