Old 02 Jan 2005, 11:20 pm
PTGT Redman PTGT Redman is offline
Anyone swap their stock PCM while leaving the larger injectors?
Are there subtle 04 GT vs 03 GT programming differences cause the S1 injectors are the same as the stock 04 injectors.
Thanks, b/c i'm prolly going to have to have my car emission tested and want to have an idea as to what I need to do.
So, NH does OBD testing, not tailpipe.
Should I or do I need to swap out the S1 PCM?
If I do, and leave the S1 injectors, will I still get appropraite parameter readings from the PCM if it is tested?
Homepage:
