03 Jan 2005, 03:27 pm
quote:Originally posted by MichaelDay
Although I don't know the answer to the question, the stock PCM on the '03 would assume that the stock injectors were in place and probably cause the larger Stage 1 injectors to push too much fuel making a richer mixture. Since the GT runs somewhat rich anyway, I wouldn't think that would be a good thing for emissions. The PCM might or might not know to back off the mixture. I'm not sure the OBDII test would know the difference for a short time which MIGHT allow you to pass the test. Unfortunately, all this is just conjecture until someone actually either passes or fails the OBDII test with Stage 1 in place or with the Stage 1 injectors and the stock '03 PCM.
Unfortunately, I don't know anyone with an '03 that has tried it either way to find out.
Not sure about passing smog but you are right about the car running rich. The PCM has the injector size programmed into it. It interprets the sensor inputs and sends a signal to the injector for a pulse width @ a given fuel pressure. A bigger injector will flow more at a given pulse width and you will run richer. Same if the pressure is greater than is programmed.
