If you can simply buy just the emblem from a dealer it should be simple. The old one is in there with 3M double sided trim tape. It shouldn't be too hard to remove. Once you get it out, just stick the new one on.
I removed mine after I drilled a couple of holes through it (see my sig.), but you should be able to pry it out.
 Black 03 PT Turbo & Black 94 Impala SS
