Old 12 Jan 2005, 10:17 pm
Dreamc2 Dreamc2 is offline
Dan the rear air bags instal in less than 1 hour all you do is jack the car up or put it on a hoist and take the lower bolt out of the shocks to drop the rear down and pull out the orginal springs put in the air bags screw in 2 self tapping screws per side and route the air line, wire tie off and drill 1 hole under the license plate for the filler valve. the front springs are 1 1/2 " drop nothing radical you have to pull the struts and use a spring compressor to change the front springs you can sign these out at auto zone or buy them. I picked up almost 2 tenths at the drag strip by raseing the rear of the car with the air suspension
