  #14 (permalink)
Old 13 Jan 2005, 05:40 pm
pd_cruzn pd_cruzn is offline
the relay is placed in the blade fuse holder that was bought at radio shack. and i ran my wire thru the hood latch pull and connedted it to the + jump post using a nut to tighten it down. if you run it thru the hood latch to the engine compartment i suggest doing it right after you have stop running the car. it make the rubber a lot softer because of the heat and was much easier. I never removed the rubber from the hole just in the firewall just used a straighten coat hanger to feed the wire thru. I did this to my pt my wifes pt and mother in law pt
