Old 15 Jan 2005, 02:29 pm
2step 2step is offline
The only way that the washer fluid can freeze is if the alcohol content is too low. The proper mix of water and alcohol won't freeze. Alcohol tends to evaporate a little sooner than water. If the washer fluid isn't fresh and has been in the holding tank for a long time, the concentration of alcohol may be low. It's best to start the cold season with fresh washer fluid.
Edit: If you have put new fluid in the resevoir, be sure to pump the old stuff out of the lines. If the "Purple Stuff" is still freezing, then it's not a proper mix and of poor quality.
