Thread: New detail tip>
Old 13 Jun 2003, 10:15 am
Default New detail tip>
Because so many people have been e mailing me on my web site asking me detail questions, I decided to post another tip. Everyone wants to keep their Cruiser in top condition, but if you drive it everyday, like most of us it is subjected to all kinds of contaminents. Biggest complaint I've heard is "how to get out surface scratches". first lets talk about how they got there. Most of time its from improper washing/drying. When the car is not prepped properly, all you do is work exsising dirt into the finish. The clay bar is the best solution to ensure proper cleaning BEFORE you polish/wax/seal. Most people never heard of clay, and if they have they don't know how to use it. After you wash your car, before you dry, feel it with your hand. A simple test is to put your hand in a plastic biggie and gently move across the finish, if it grabs a little, you have fine particles of dirt that you did not remove while washing. HOW TO USE CLAY. first get yourself a fresh bucket of soapy water. break off a small piece of clay in your hand, (clay works best with lots of lubrication) lather a small section of your car, dip the clay on the water, spray the clay with quick detail spray, gently work the clay in a side to side motion. (don';t press to hard, it works well with gently pressure) after 4-4 strokes, spray again, lather, and do another section. keep dipping clay in bucket, keep spraying with QD, work side to side. YOu will see (and feel) the finish getting cleaner, your hand will start to get the hang of it,(if the surface gums up, it is not libricated enough) once you get it down, its easy. The key is lubrication, gentle side to side motion. also, after a few sections, press the clay in your hand in and out, making a fresh surface. it looks and feels like play dough, so you can made a new surface by working it. One piece will do the whole car. IF YOU DROP THE CLAY THROW IT OUT, USE A NEW PIECE! it will pick up dirt from the ground and become a hazard, working like sandpaper. after you do the whole car, wash car again to remove clay residue, dry with lareg micro fiber or high quality 100%cotton terri towels. proceed to polish/wax/seal> Hope that helps. www.perfectautofinish.com Gary
