Old 17 Jan 2005, 09:02 am
gonzomania's Avatar
gonzomania gonzomania is offline
Send a message via AIM to gonzomania
I believe the part # is 5016951AB @ $65.00. You can Check this site: https://www.1stchryslerparts.com/oe_parts_catalog.html I use collision side and it works better. To install remove the negative battery cable, this stops air bag from being deployed. Remove 2 Phillip head screws from the steering column cover. After cover is removed ther are 4 torx screws (I believe they are a 10 or 15 mm torx). Remove the electrical connectors from the back of the switch.Reinstall to new mutifunction switch and tighten 4 torx screwsand reinstall column cover. Hope this helps by the way welcome to the forum.[?]
Gonz
