In Mass you get a 2 year free pass on emissions as I recall for a new car, so you wont have to worry until 2007
I would definalty get stg1, your worst case situation, you might have to spend 10 minutes swapping the PCM, really easy. Go for it and in two years try to see if it passes, if not just swap the stock PCM back in.
I have an 03 GT 5spd. Dynoed it in NE Dyno in Worcester, got 225 WHP, 252 WTQ.
Mike
86 Daytona Turbo Z CS T-Tops 2.2 +20\'s A555 Getrag moly plate, Garrett T2 3\"SV 3\" exh GLHS Stg 2 20 PSI Boost
89 Shadow ES Turbo 2.5 T2 Garret A555 Getrag moly plate 2.5 exh
89 Spirit Turbo
90 Daytona ES Turbo 2.5 NPR Cooler, S60 50 Trim, A568 Getrag 3\" Exh +40\'s 3bar Map
90 Daytona Shelby VNT 2.2 T4 A568 Getrag Needs work
00 Durango 5.9 SLT+
02 WJ Grand Cherokee Laredo 4.7
03 PTGT Black 5 spd, Stg1, Mopar BOV
