Thread: Oil Leak
Old 19 Jan 2005, 01:53 pm
Ant Ant is offline
quote:Originally posted by PT Woody
I'll check the filter. Are there any
sending units back there ?
Thanks.[8]
Yes. This also what you consider to be the "back" of the engine.
There is an oil presuure sending unit located in the middle of the block (top to bottom), on the firewall side and more towards the driver's side.
PT powered PT with:
Fully built HRC Turboed 2.4: Wiseco pistons, T2 rods, Port & Polished head (Bob Special) with oversize Stainless Steel valves, #14 Crane Cams, AF/X UDP, No balance shafts, Custom 3\" downpipe, 3\" hi flow exhaust, Ported GT intake manifold, Bored Throttle Body, 30 lb injectors, Water/Alc. injection
