Old 19 Jan 2005, 03:26 pm
TurbozCS2003 TurbozCS2003 is offline
Gary
You already have a BOV in a way, when you lift the solenoid ports vacuum on the diaphragm on the turbo and it releases the presure into your air box. Hence it is quiet. THe bov is simply a plate with passage ways machined in it which bolts to the turbo.It release the pressure to atmosphere instead of your air box. Hence more noise
I think you are the type who would like it, my wife drives our PT and enjoys the whissssh when she hammers it and lifts on the throttle.
VNT
86 Daytona Turbo Z CS T-Tops 2.2 +20\'s A555 Getrag moly plate, Garrett T2 3\"SV 3\" exh GLHS Stg 2 20 PSI Boost
89 Shadow ES Turbo 2.5 T2 Garret A555 Getrag moly plate 2.5 exh
89 Spirit Turbo
90 Daytona ES Turbo 2.5 NPR Cooler, S60 50 Trim, A568 Getrag 3\" Exh +40\'s 3bar Map
90 Daytona Shelby VNT 2.2 T4 A568 Getrag Needs work
00 Durango 5.9 SLT+
02 WJ Grand Cherokee Laredo 4.7
03 PTGT Black 5 spd, Stg1, Mopar BOV
