Old 29 Jan 2005, 07:38 am
hyracer hyracer is offline
Tom,
Get ahold of the guy and see if his cruise control and A/C works. If I remember right there is a differance on how thoses are configured between the two cars. In fact I don't believe the SRT4 even has cruise-control. When 3-bar-boost was around I believe those accessories were mentioned that may not work if an ECU was switched between the two cars. Something also tells me there may be a problem on how the radiator fan is controlled to.
Deen
