Thread: were is it
Old 02 Feb 2005, 10:59 am
tpscruiser tpscruiser is offline
The drain is on the drivers side at the lower, engine side of the radiator. Just turn it counter clockwise about 1/4 to 1/2 turn. there is a small round port you may be able to put a small hose on to guide the fluid into a container. DO NOT OPEN THE DRAIN WHEN THE ENGINE IS HOT AND/OR UNDER PRESSURE! If you just want to drain down some of the fluid out of the engine, remove the radiator cap, otherwise you will drain the Coolant Recovery Tank before the level drops in the engine.
Don't forget to bleed the air from the system as you refill the radiator.The bleed screw looks like a brake bleeder screw, below the radiator cap. Open the screw and fill the system until fluid comes out, tighten the bleed screw and finish filling the system.
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
