Old 03 Feb 2005, 02:11 pm
Cal Cruzer Cal Cruzer is offline
quote:Originally posted by DARK270
i dont really want to lower mine..just want better handling and response.....in part...better performance...what do you think?? is it worth 1500$$
Unless you have a shop with a lift and can weigh the corners and have a in depth knowledge of setting up a coil over suspension, preloads, etc, you would be better off just getting a good set of springs. While you can, in theory, just throw a set a coilovers on the car, you will probably not improve handling unless you have a suspension guru set it up properly for you. A good set of springs and shocks/struts and sway bars is more than sufficient for most street applications. YOu didn't say if you were planning on road racing or what. Coil overs are cool but way expensive and even more expensive to have a race shop set up for you so the car is balanced. This is a process that involves intial weigh and setting, taking it out on the track for testing, bringing it back for more adjustments in response to your track test and doing it again, and again, and again if needed...
