  #15 (permalink)
Old 03 Feb 2005, 07:44 pm
fugitiveALiEN fugitiveALiEN is offline
Send a message via AIM to fugitiveALiEN
quote:Originally posted by Sci-Fi
quote:Originally posted by zoned
Would there be more of a handling improvement in the corners if a rear sway bar was installed instead of a strut bar? I've an '05 Touring.
In a word, yes. BUT instead of just adding the OEM rear sway bar, it would be better to buy an aftermarket matched F/R sway bar set plus the rear installation kit (you need to buy the installation kit for either). The OEM rear bar will cost about $194.27 plus another $90 for the installation kit, while a complete aftermarket anti sway bar set will run about $265.01 (for Eibach, the most popular choice at the moment) plus the cost of the rear installation kit. So you are only looking at a $70 difference and the handling will be far superior than just adding the OEM rear bar in. The ride quality will not be affected.
Intrax offers grease fittings/greasable bushings with their anti-sway bars (part #28.7.009), 25mm front/19mm rear diameter bars and are purple powder coated. Can visit my site, http://sci-fi.ptenthusiasts.net/photo6.html , and see the various available anti-sway bars and strut bars plus their respective part numbers for the PT.
Most people have both the strut bar and aftermarket anti-sway bars installed. The strut bar will help prevent or tie together the shock towers to control upper body flexing in the front end (better steering response and slightly better handling) and the anti-sway bars will control body roll/lean (better overall balance/handling).
The only concern about the strut bar is the installation. Some people over-tighten the nuts and/or do not tighten/torque the nuts in even and equal stages and end up breaking the stud(s) causing an expensive replacement of the top strut plate (some get lucky and can get a replacement stud or bolt in there w/o taking everything apart).
Hope this helps...
[8)]
Sci-Fi, is there a safe for work version of your page? The babes aren't so easy on the wife or the bosses eyes and pink slips =[:0]
