Old 04 Feb 2005, 08:45 am
quote:Originally posted by SRG
Hmmm, 2 2002's, at close to the same mileage, with the same leak in both the power steering gear and transmission solenoid packs. This isn't good..... anyone else??
SRG
I have a 2002 with 82,000 + miles now. I had a miss between 20 & 30,000 miles that Cranes wires cured (permanently, plugs didn't help).
I took it in recently because after hitting a pothole that was bad enough to crack an alloy wheel, the car didn't feel right. I had a 4-wheel alignment done and they found I had a broken sway bar! Can't happen on new PTs - no sway bar!
Other than that, and a suicidal deer, have had no problems. Has just begun to use some oil.
