Old 05 Feb 2005, 01:55 am
1ptturbo 1ptturbo is offline
quote:Originally posted by hoopdiewagon
SIII can run 26psi because a different turbo comes in the package. A stock turbo will not like that much boost for very long.
He just means the engine itself can take up to 26 psi, our tiny weeny turbo will lose it's efficiency well before 26 psi and I really doubt whether it can hold 22psi all the way to red line.
Skripo, I don't see where you tied all these components together to form a complete system.
Are you recommending using a 3bar map and clamp it or just fool the stock map. What about the throttle inlet pressure sensor it also reads boost and needs to read 3bars, how do you control this sensor from pulling timing? Are you bypassing some or all the boost control solenoids, WGA, Surge Valve and Tip?
[:I]
