Old 10 Feb 2005, 11:15 pm
slartyblarfast slartyblarfast is offline
The high idle speed is more than likely caused by a vacum leak.Most likely you probably forgot to hook up a vacum hose. This will also cause the Check Engine light to come because the engine is now running too lean. Check all your vacum hoses and electrical connectors on the intake manifold.
