  #13 (permalink)
Old 14 Feb 2005, 01:16 am
Tw3NTy0n3 Tw3NTy0n3 is offline
Send a message via AIM to Tw3NTy0n3
quote:Originally posted by MX-5
There's one downside to this idea.
The PCM doesn't read the air temp sensor above 85% throttle angle.
This means that any resistor will be useless when you step on it.
Above 85% throttle, the PCM goes into a pre-programmed fuel and ignition strategy. The mid-throttle timing will advance as far as 37 degrees. At WOT, the most advance you will ever see is 24 degrees.
Chrysler uses a very conservative PCM strategy to keep the motor running for a long time.
Do you know if that's the same with the early model PT's? I know some things are different like the speed limiter because I've hit 120mph in mine.
http://cardomain.com/id/tw3nty0n3
Stone White 2001 . True Cold Air Intake . Burp Free Shift Mod w/ Switch . Freedom Design Strut Bar . Dynomax Turbo Muffler . Pioneer MP3 CD-Player . Kenwood C6889IE\'s in the back . Alpine SPS-170A\'s in the front . 2 12" Subs @ 1200 watts each inside a C4 . 600 watt 2 CH Amp .
SOLD!
Proud member of Critical Damage Automobile Club©
