Old 16 Feb 2005, 01:18 am
SuGamer SuGamer is offline
quote:Originally posted by bnorth
Somewhere I read that if you install platinum plugs you must change the engine timing. The rational was that the spark was impressed farther into the chamber (closer to the piston) and therefore the timing had to be changed.
Anyone know the truth to this question?????
Thanks, Bernie
No, no, no! Who told you that?? The idea behind platinum plugs is to have a better spark and smoother idle. Besides, whoever told you that failed to mention that you can't adjust the timing; it's controlled by the PCM, unless you go with an independant ignition system. I did read however, that the double platinum plugs are not recommended for the turbos.
