<h3>Review: Keystone Single Port GoodHood (GHD-PT1) for the PT Cruiser (2001-2004)</h3>
http://www.keystonerestyling.com/cgi...alogno=GHD-PT1
*Note: Some of the images on the "Larger View" links have dimension and other info on the larger pic that you won't see on the thumbnails, so click the "larger view" for more specific information.
This was installed on a 2003 GT model. Some sites still list this hood as not fitting the GT but don't believe 'em. It may not have been designed on the GT frame but it fits perfectly and requires no modification aside from normal alignment. Also you don't have to get the Keystone CAI box, I have the Airaid CAI and it matches up perfectly.
I purchased the hood through BTG (
http://www.btgmotoring.com) and had it painted locally. I'm lucky I suppose in that I don't have a paint scheme on my PT so the cost wasn't huge. Unless you come across a deal somewhere, you can expect to pay around $1000 total for the hood itself and your basic single color w/clearcoat.
What you get:
1 Gel-Coated Fiberglass Hood
1 Metal "Keystone" adhesive-backed plate
1 Multi-Color "Keystone" Sticker
1 Install Instruction Page
First off, you're going to need a fair amount of room. For install as well as just somewhere to put it when it arrives. The delivery box is huge. Be sure to open the box and check the hood before the delivery guy takes off. The packing set-up isn't the most reliable so there is a small chance it could have been damaged during transport if it was handled improperly. Remember if the guy takes off and it turns out it's been cracked it'll come out of your pocket unless you inspect the hood while he's standing there and refuse delivery if it's damaged.
Test Fit:
The first step is to remove the hood liner and the stock hood.
Drop Cloth!! The hood liner is held in place by 10 small star plugs. They are a bit of a pain to remove which will be made worse if you drop some of them down into the engine bay. Placing a large towel or drop cloth over the engine will save you from having to hunt them down if you drop a few while taking them off. (See below)
Larger View: (
http://www.robertsmedia.net/pt/hood_..._removal_1.jpg)
The star plugs have two tabs that hold them in place. It may be difficult to see because they have three wedge shaped flanges that do a great job of concealing the tabs. The easiest way to remove these plugs is to use a small flat head screwdriver (about 1/8-1/4" blade) to lift one of the flanges a little then slide the screwdriver underneath it to depress the tab on one side, keep a little tension on the flange to keep the tab from snapping back in and you can slide the screwdriver in on the opposite side to get the second tab. It seemed best to use fairly light pressure with the screwdriver. It you push too strongly the tabs seem to either jam or the outer part of the tab breaks off and you end up having to just yank the plug out.
Once all the plugs are out the liner will fall away and you've got a good look at how the stock hood underside relates to your new Keystone. Some things you should note: The holes used by the some of the hood strut kits does not exist on the Keystone hood, also neither do the metal retainer clips for the washer hose or the mounting hole for the washer tubing's "T" fitting on the driver's side.
Larger View: (
http://www.robertsmedia.net/pt/hood_..._removal_2.jpg)
I'll revisit this later but it's something to keep in mind if you're planning on a hood swap like this.
Screw the front bumpers down a few turns, the black rubber knobs on the frame around the hood latch assembly. Just twist 'em a few times, they should have a alignment mark on them so you can set them back to the original height. Disconnect the washer hose and if you've got hood struts remove them as well, you can use the stock
