Those are the screws you need to remove. When you do that the whole assembly will come loose. It is a very large part there are two wire connectors that have to be taken off. If you change the MF switch, don't for get to remove the flasher unit from the back of the MF switch and replace it on the new one.
IF you want pictures and all instructions from ptdiy.com. It costs $15 to join and is well worth the money.
