Thread: EGR Valve?
  #14 (permalink)
Old 22 Feb 2005, 04:31 pm
quote:Originally posted by SuGamer
quote:Originally posted by patbluecruiser
Back to the EGR question. I replaced my spark plugs about a month ago and only had to remove two bolts that attached the TB to the "engine". I used this as a guide:
http://www.imagestation.com/album/?id=4291473219&idx=0
I did not see the EGR valve.
-Andy
Check again, you had to remove 2 other bolts and pull the manifold towards you to pull it off of the egr's tube.
2 different sized bolts, and one on the throttle body. Is the EGR valve at the other end of that tube? [:I]
