I had my lower control arm bushings replaced on my 2003 GT with 25,000 miles on the odometer (warranty item). They just remove the old bushings and press the new bushings in. They will not replace the whole lower control arm.
BTW, the reason I knew the bushings had to be replaced was due to a "clunk" sound whenever I hit a bump. It sounds like the front sway bar is loose but upon further inspection it was not. The clunk sound is the lower control arm hitting the frame.
Scott
\"If you choose not to decide, you still have made a choice.\"
