APC tails condensation problem fixed
I had problems with condensation in my APC gen II tailights. Called APC no help said I should return to place I purchaced from.[xx(] Well to make a long story short after getting the run around I decided to fix them my self. After removing the offending tailight I drilled a 1/8 hole in the backside of the light near the top. Also on the side under the reflector so it will not be seen. I reinstalled the light and checked to see if you can see the hole I can`t. Well the light has been on for about three weeks now and the condensation has cleared up and not returned.[?]
