VK, take my advice and do this.
There are 4 screws holding the door panel to the door. Just look for them. Dont forget the one behind the door handle. After that, the door just Pops off. Start at the bottom, after you get it about halfway popped out, reach up and see if you can feel (or if you can see from underneath) a yellow connector that connects the door pin to the locking mechanism. After you pop that off, go ahead and Lift the door out of the door sill. Then you can see where the door lock switch is attached with 2 philips head screws. Remove that first. If you dont have the replacement already you can just put the door back on and let the wire hang out until you get the part. When you get the part (search the forums for some reliable places,) just plug the switch in, screw it back in, and reattach the door. If you need help, just email me and I can walk you through it.
About to start work on modding my car and making it look even better than it already is!
