quote:Originally posted by quicksilverdon
I didn't know PS pump would throw a code.
There is a power steering pressure switch that tells the PCM to increase the engine rpm during increased load on the pump. This is easy to see. With the engine at idle in gear, turn the wheel sharply. You will see the rpm increase just over 100 rpm to compensate.
