The problem you will encounter is that even though you programmed it to not automatically lock when you put the car in drive, the switch will still try to unlock the doors. Even if you take the fuse out....It is quite daunting I know.....but if you gently pull the door will pop off, trust me. If you need help VK let me know. Im here for you
About to start work on modding my car and making it look even better than it already is!
