Old 26 Feb 2005, 02:03 am
robinjoe robinjoe is offline
Here is another "newbie" question:
Will an otherwise identical (make and model) 7" wide tire last longer than a 6" tire?
It would seem to make sense since the tire will be slipping less, and the weight is distributed across a larger area. Don't you use a lower tire pressure on a wider tire since you are distributing the weight across a larger area?
Also, how reliable are the tread wear, traction, and temperature ratings printed on the sides of the tires? Are these determined by the manufacturer, or a standards testing agency of some sort?
Joe R - 2003 Electric Blue PT Cruiser GT Turbo
http://www.pbase.com/robinjoe/pt_cruiser
