Old 08 Mar 2005, 02:46 pm
idigrocks idigrocks is offline
I have experienced the problem you described. My dealer said there was a TSB about it but there was no fix. I solved the problem by stuffing a few pieces of foam rubber into the area through the opening for the dome light. Just make sure to get it far enough back so it doesn't interfere with the sunroof and shade panel but not so much that you push the headliner down even further. A very annoying situation that I refused to give up on, although the dealer did. Getting the dome light back in is a little tricky so be very observant when you take it out.
