Old 14 Mar 2005, 06:31 pm
MichaelDay MichaelDay is offline
I belive Depot3d was looking for instructions for programming the transmitter rather than the key. Page 21 of the 2003 PT GT Manual:
"Up to four transmitters can be programmed to your vehicle. Your new vehicle was shipped with two transmitters. See your dealer for additional transmitters
Additional transmitters can be programmed to the system by using the follow procedure:
1. Insert the key into the ignition switch and turn the switch to the ON position.
2. Press and hold the Unlock button on the transmitter between four and ten seconds.
3. continue to hold the unlock button and press the Panic button. A chime will sound to indicate that the transmitter programming mode has been entered.
4. Press a button on all transmitters to be programmed to the system, including any previously programmed transmitters. A chime will sound when each transmitter has been programmed.
5. Turn the ignition switch off to exit the transmitter programming mode."
