Thread: Fog lights
Old 16 Mar 2005, 05:55 am
gonzomania's Avatar
gonzomania gonzomania is offline
Send a message via AIM to gonzomania
I looked for my instructions and can't find them. I'm off tomorrow and I'll look again. Do you have the light blue wiring down where the fog lights would go? That wiring plugs into the fog bulb. Also if I remember correctly if you remove the 2 phillips screws from the upper and lower steering column shroud. unsnap shroud, this exposes multifunction switch. Remove plug to back of multifunction switch, I think you have to slide 2 tabs to remove. Look into the plug If I remember if there is a light blue wire going into pin 8 and out of 14 your wired. Should be same colored wire that would plug into your fog lights under the car.
Gonz
