quote:Originally posted by MARKS-GT
GO WITH A HIGH FLOW CAT OR CAT BYPASS AND HIGH FLOW EXAUST WITH A TURBO MUFFLER. THIS WILL MAKE A 10-15 % INCREASE IN POWER. YOU WILL NOTICE A HUGE DIFFERENCE WITH THIS ON A TURBO CAR. YOUR TURBO WILL SPOOL FASTER, REDUCE LAG AND GENERATE HIGHER BOOST. CAT'S ARE WAY TO RESTRICTIVE.
[8)]
Hit your Cap Lock button and loose all caps...considered bad etiquette
on the Internet. Also we appreciate your enthusiasim but you need to read for a while and maybe do a search. Exhaust systems and cat-back exhausts have been mentioned hundreds of times already.
Deen
